- 18 Oct 2002
- In my own little world
Hi
I am way out of touch with PC builds, not had to do one for long time.
My son has my old PC, basically used for playing Minecraft and Skyping his friends.
It was smelling of burning so I took it apart and it was basically thick with dust. Took CPU cooler off to clean everything. I managed to break 2 of the plastic clips on the 4 pronged cooler base, which uses the plastic clips to secure into the mobo holes.
It is an Asus P5K Premium with a Q6600 and DDR2 memory (if I recall)
Has a HD5850 GFX card which seemed fine for Miecraft.
Questions are;
1. Is it easy enough to get a replacement cooler base, or the clips (which do come apart)?
2. Replace minimum parts to get it up again, in other words can I maybe get a cheap mobo/CPU/Cooler and re-use DDR2 memory and GFX card?
3. Easier to get Mobo/CPU/Cooler/Memory/GFX card for under £350?
Sorry for long winded post, wanted to give background for questions
Thanks in advance for any guidance
Questions are;
