- 4 Jun 2010
What's the beat way to apply thermal compound to my i5 750 with a - Akasa Venom CPU Cooler and thermal compound in the shape of a searinge
Thanks
Thanks
Did the thermal compound come with the cooler or is it a after market one like MX-3 or AS5.
It is aftermarket
Do you know the name, as different manufacturers recommend different ways.
Youtube is your friend, do a search for applying thermal paste.
There is basically two schools of thought. You either apply a rice sized blob in the centre of the CPU and the pressure of the heatsink spreads it over the chip. Or you apply a thin line and use a bank card (or spreader if supplied with the paste) to smear a thin layer over the cpu then mount the heatsink.
Hope this helps
