14 May 2024 at 14:19 #1 RobTi RobTi Associate Joined 23 Jan 2005 Posts 1,454 hi i want to use 3 nvme drives but have all six sata ports in use, can anyone help on which i can use on a gigabyte Z690 gaming x ddr4 mb https://imgur.com/a/inkDs1k
14 May 2024 at 14:28 #2 Tetras Tetras Man of Honour Joined 22 Jun 2006 Posts 16,920 It looks like you just need to avoid the bottom one (M2M_SB) and you're fine.
14 May 2024 at 16:29 #3 RobTi RobTi Associate OP Joined 23 Jan 2005 Posts 1,454 Tetras said: It looks like you just need to avoid the bottom one (M2M_SB) and you're fine. Click to expand... thanks for taking the time to help, i kind of thought that but it helps to have someone confirm it for you
