- 7 Feb 2008
Asus M4A89GTD PRO intermittent lan problem. Help mr -VK-??
Just put my pc back together after installing a new motherboard, memory and cpu. I have an Asus M4A89GTD PRO but it will not recognize my Ethernet cable
I have the lead plugged in the back but none of the lights either side of it are flashing, the drivers are installed and i have disabled it and reinstalled them a few times and as far as windows is concerned it is working fine. I have windows 7 ultimate 32bit installed at the mo and when I click on trouble shooting it tells me there isnt an ethernet cable plugged in, but if I pull it out and plug it into my macbook it works fine. Any ideas??
