Help - One Card - Two Monitors
10 Jan 2012
NW UK
Hi guys
SOld my old rig and it has an EVGA 8800 GTS KO ACS3 650MB Card in it
Need to use the machine to power two monitors, both flat screens
Spec sheet can be viewed here:-
http://www.evga.com/products/pdf/640-P2-N827.pdf
The card has (two) 2 X dual link DVI outputs
I have one adapter/connector block on back iof card that is 15pin VGA D sub type
How can I connect the 2 flat screen LCD monitors to this card so I can have one desktop across two screens?
Regards
Lew
You can have 2 monitors with extended desktop, download the latest drivers form nvidia and install then. Then go into nvidia control panel and check the settings.
Hi guys
Was on about the port/connectors, not the software
Monitors are Dell 20" with just one 15 pin VGA connector
Graphics card twin output are DVI-I
Thats what confusing me
Lew
You need a couple of DVI to VGA adapters, tis as simple as plugging them in.
** No hotlinking **
DVI-I Should be able to use adapters for vga.
The four pins around the - carry the analog signal. (Iirc)
DVI-D won't be able to.
