help overclock 290x
18 Dec 2010
I have installed the TriXX software and I can only see GPU clock, Memory clock and VDDC. Will I need to increase power limit when overclocking? should that option be on the software?
Thanks
I set it to max, it allows the card to pull more than the 300W limit (although that maybe for a reference card that has a 6pin+8pin) it normally does.
Temps and voltage are the ones to keep an eye on.
