Help Overclock E6600/Asus P5B
11 Oct 2005
Doncaster
Intel E6600
Asus P5B Deluxe
Geil 6400 Ultra low
I want too try and get around 3GHZ on this little beauty....Can someone please give me some tutorial on how too and which settings too change in the BIOS so i can achieve 3GHZ. Also how too get the RAM running on 1.1.
Some pictures would help also ;)
Thank you for all advice in advance.... :D :D
Can anyone help me better this please....3GHZ i'm looking for.
Well i can't work this Asus AI software out at all.
I set it too 2.8GHZ...FSB on 667....Ram ratio on X8 but when it reboots it keeps putting it back too 2.52GHZ ....280 x9.
Can anyone give me any advice on what too do in the BIOS instead of using this unwanted software.
Right just tried too run a CPU test on both CPU's and it rebooted after about 3 seconds. I am not going too bother anymore with trying too overclock the CPU all i want too do now is get the specified timings on the RAM.
Can you tell me how too do this please m8 because everytime i try and do it manually it just goes back too this.
lol,
Increasing voltage = higher temps.
1.3V is probably lower than what the chip was given before, probably about 1.26V real.
and anything under 60C is fine.
When i went into the BIOS m8 it was set on Auto so i had no idea what voltage it was actually on...I took the reading off Everest which said it was on 1.2....The Temps on 1.2 were hitting 53/52 as you can see in the picture...I changed it too 1.3v and it's gone down
