I'm trying to do my first oc on my e6600 on a p5n-e sli board. I've read some articles and forum posts, but I'm still not sure what I'm doing wrong.
I unlinked the FSB and memory clock. They are set at 1066 and 667 respectively at stock.
I then tried to up the FSB to 1100, and the actual memory clock went down to 660. I then exited BIOS and nothing happened on restarting. I then turned off and powered up again and it came up with POST error and to reset the things I changed. It also says that the memory timings are 5-4-4-14, when they should be set at 5-5-5-15 (and are currently running at this).
So what am I doing wrong and how can I get my oc working
), it reboots after a while....still havent solved this....even after the addition of a Asus HD4890 card. Hope you get some useful info from the thread.
