Hi there,
I'm having some trouble overclocking my E6750 - the best I've managed so far, which seemed relatively stable, is 3.2GHz. This is slightly disappointing as I was hoping to hit at least 3.4GHz. My hardware:
C2D E6750 (Step B, Rev G0)
Gigabyte GA-N650SLI-DS4 Motherboard (F7 Bios)
2x 1GB OCZ Reaper PC6400 RAM
Thermalright XP120 + Noiseblocker 120mm SX1 Fan
First of all I dropped the multiplier and pushed the RAM to find its limit. The best I achieved was:
424Mhz (848DDR) 4-5-5-15 2T, 2.2V (Northbridge +0.2V, FSB +0.2V)
Whilst I found this slightly disappointing, it's not all that bad.
Then I held the RAM at 800 (or less) whilst pushing up the CPU speed. At stock voltages, I managed to get to 3.1GHz (8 x 387.9) then had to push the voltages hard to get 3.2GHz (8 x 400):
NB +0.3V, FSB +0.3V, SB +0.3V, VCC12 +0.2V, CPU 1.55V (read as 1.504V)
I've also tried turning the various speedstepping things off and on, but that doesn't seem to make much difference. I also dropped the LDT to 4x to hit those speeds.
At the current CPU overclock I don't even need to push my RAM at all, so that disappointing first RAM go was not even needed! I'm sure I'm missing something fairly crucial here, so any comments or suggestions are really appreciated.
Oh also, I tried to push it to 3.3GHz (8 x 413), syncing the RAM and also having the RAM at stock. I had all the voltages on the mobo maxed out, and the CPU at 1.5875V and it still wouldn't boot.
