Hi, First time ocing i7 so would appriciate is somebody can validate my overclock.
Specs -
i7 920 c0/c1 W/ultra 120 Push Pull setup
P6t6 Ws Revolution
Gtx 280
6gb OCZ blade pc3-1600
1000 jeantech modular psu
Cosmos S case with 9 after market xigamtek fans and side window
overclock -
3.6ghz @ 1.23125v - 20 * 180
1.44v dram ram running at 1800mhz
everything else is stock & enabled
Temps idle @ 38c full load prime small ftt @ 70c
Cant seem to get to 4ghz for some reason even with loading up on volts. I havnt changed any setting apart from cpu volts and setting ram volts at reccomended manufactuer setingd. I was thinking maybe i had to tinkerwith something else but dont know where to start. any help pls
Specs -
P6t6 Ws Revolution
Gtx 280
overclock -
