- 7 Jan 2007
- Sussex, UK
I have read that almost all the Phenom II X4s struggle to get 4GHz without major increases in voltage. With more voltage comes more heat, that is inevitable. The only thing that could be leading to the instability in prime looking at your settings is not enough voltage imo.
It needs huge volts of 1.525 volts to work then it reaches 57C. I'm gonna leave it on 3.8 with stock volts.
Ah right, what is your airflow like?
is prime really necessary if all you do is game? [that's if all you do is game] Won't 3DMark be a better option for testing?
Probably better leaving it at 3.8 I bet the extra 5% in Ghz wont translate to 5% more performance especially with the amount of volts an heat that would be pumping out, maybe better trying to get a higher northbridge frequency
What am I doing wrong?
