Hello everyone, 2 months ago i completed my first pc build.
I want to overclock my cpu to see if it improves gaming in general.
i mainly play FPS.
I already OC this to 4.5hz and it seemed stable but i took it back to stock cause i wasnt sure if everything was ok(i followed a youtube video that has the same cpu and mobo)
I have stressed for 2 or 3 hours and temps were max at 72*C
Now i improved my iddle temps by 10*c and wanna try it again
(My cpu is at 27*C,30*c on iddle)
This is my setup
CPU Intel Core i5-2500K 3.3GHz Quad-Core Processor
CPU Cooler: Cooler Master Hyper 212X 82.9 CFM CPU Cooler(with 2 high cfm fans from corsair)
Motherboard: Gigabyte GA-Z68AP-D3(R2.0) ATX LGA1155 Motherboard
Memory: Patriot Viper 3 16GB (2 x 8GB) DDR3-1600 Memory
Storage:
Seagate Barracuda 1TB 3.5" HDD
Western Digital Caviar Blue 1TB HDD
GPU: Sapphire Radeon R9 280X 3GB Tri-X Toxic Video Card
Case: BitFenix Nova ATX Mid Tower Case
Power Supply: EVGA 600B 600W 80+ Bronze Certified ATX Power Supply
Optical Drive: Asus DRW-24F1ST DVD/CD Writer
OS: Microsoft Windows 10 Pro OEM 64-bit
Case Fan : Corsair 120 x2 120mm 2k rpm
If someone can guide me trough it would be much appreciated
Can someone help me with this?Thank you
i mainly play FPS.
This is my setup
Storage:
