Help Overclocking my X6
30 Nov 2010
Caerphilly
Got a stable overclock to 4.2GHz
Validation: http://valid.canardpc.com/show_oc.php?id=1560087
FSB/Multiplier:300/14
CPU Speed:4200
NB Speed:3000
HT Speed:2400
CPU Voltage:1.47
CPU-NB Voltage:1.35
NB Voltage:1.28
RAM Speed:1599
Motherboard:Gigabyte 790FXTA-UD5
Model: 125w
But i ran Prime95 for 1 minute and CPU Tempature in EasyTune6 is reporting as 66C+.
Cooler: CoolIT Vantage (Push/Pull setup)
I made sure i totaly bolted down the water block and still the same :/
Any suggestions?
I just reseated the water block once again and used a thicker screwdriver to screw it on, (re added termal paste also) and when i mean bolted, i mean bolted! and now it won't go past 60C under full load in Prime95. I had to bring down the clock back down to 4GHz "Stable" and It's fine now but i would appreciate any other suggestions :)
