Help Overclocking PII X2 550BE
18 Dec 2005
Contin, Highlands
I am currently stuck at 3.6 OC, my stats are
Bus Speed 200 X 18 = 3617
VCC:1.45
Temp Core Idle:29C Load:39-40C
Temp CPU Idle:38C Load: 48-49C
Ram: DDR2 800 - Stock volts and timings(1.8v - 6-5-5-18)
HT: 1000 - max on this Mobo
NB Frequency: 2200 - max on this board
Cooling: Corsair H50 Single fan
My question is if I get a higher HT & NB Frequency will this provide a faster OC?:confused:
Many Thanks
Demonstag
Probably not going to be noticable - have you tried upping the timings? Also check the rated frequency of the RAM. What's it running at?
The RAM is running at stock voltage and the timings are Auto. Do you have any suggestions on RAM timings as I have never changed any of them before.
HT wont make a great deal of difference, but NB should. The stock should be 2000mhz,and i can get mine to 2500mhz (although most hit 2600-2800 and ive seen a few 3000 ones floating around).
The current mobo will not boot if I increase the NB frequency above 2200 I think this has something to do with the HT being limited to 1000. I maybe wrong!
