Hi guys
Im looking for a bit of advise for overclocking my Q6600 2.4Ghz
Im using a Asus P5N32-e SLI Plus Motherboard with 4GB RAM at 667Mhz
I can clock the CPU to 3GHz with the following settings in the bios
FSB 1333
Overvolting
Vcore 1.30000
NB Core 1.30v
SB Core 1.50v
CPU VTT 1.30
Everything else is on auto
The problem i have is that when i run the IntelBurn stress test tool it tells me the test is finished after 5 seconds of running it. When i try to reboot the PC hangs but then sometimes boots with these settings.
Would buying better cooling or even going to water cooling with say the Corsair Hydro H70 help with the instability ?
Many thanks in advance.
FSB 1333
Overvolting
Vcore 1.30000
NB Core 1.30v
SB Core 1.50v
CPU VTT 1.30
