Help overclocking with CCC overdrive
7 Aug 2010
Hi, can anyone give me a clue as to the following problem.
I have two Sapphire HD 5850 (both identical) running in crossfire mode. I am trying to overclock them a little but have a curious issue.
In CCC>Performance>AMD Overdrive both my cards are listed as ATI Radeon HD 5800 Series, one as (DDC Display), this card will only allow me to go up to 775 MHz GPU clock and 1125 MHz Mem clock whereas the second card allows me to slide the bars up to 900MHz and 1300 MHz respectively. As i said, both cards are identical!
I'm assuming I need to apply the same O/C to both cards so I'm stuck. Any help much appreciated.
