Help Overclocking XMS2 Ram on Asus P5e Mobo
24 Aug 2007
My PC specs are in my sig below.
Never really overclocked before; so i need some help. I want to overclock my ram from 800mHz to 1066Mhz to achive a 1:1 FSB to Ram ratio (if i am correct in saying) I have managed to change the CAS timmings from 5-5-5-18 to 5-4-4-12. However when ever i try to increase the Rams speed from 800Mhz to 852Mhz or higher i get a BSOD. I have read that increasing the DRAM voltage could help; which i did change to 2.1v but still no luck can anyone help me out?
1:1 ratio for your CPU at stock is 600mhz im afraid, not 1066 ;).
1066mhz on ram 1;1 will get your cpu to almost 4.3ghz .
And I found this rams not OCing too well, also you have to up the timings the more mhz you want, not take them down.
It might be just your sticks not OCing too well, simple. Try 6-6-6-18 870mhz and see if that works.
