Dear All,
I am in the need of expert help, as I am overclocking my current pc speced below;
Intel Core i7 920 D0 Stepping (SLBEJ) @ 3.80 GHz
Gigabyte EX58-UD5 Intel X58 Motherboard (Bios F12)
Patriot Viper 6GB DDR3 PC3-12800C8 1600MHz DDR3 Bundle
Coolmaster Cosmos RC1000 case - all fans replaced with Scythe Kaze-Jyun (2000 rpm)
Corsair H50
Asus 6870
OCZ Vertex 2E 60GB
500GB Western Digital Hard Drive
1TB Samsung F1 Hard Drive
I have used the guide http://forums.tweaktown.com/gigabyt...i7-920-gigabyte-ex58-ud5-latest-f12-bios.html
However I changed of the settings in order to get my pc stable. But it crashes after 5 mins of prime95.
Room temp: 22.8C
CPU temps @ idle: 36 - 40C
Load temps (after 3 mins are 64 - 72C
I would be grateful if some experts can help go through my settings in order to get it stable. After this I would like to increase my overclock to 4.0 GHz
MB Intelligent Tweaker M.I.T) Settings 1
Advanced CPU Features
CPU Ratio 19x
CPU Frequency
Intel® Turbo Boost Tech. Disabled
CPU Cores Enabled All
CPU Multi-Threading Enabled
CPU Enhanced Halt (C1E) Disabled
C3/C6/C7 State Support Disabled
CPU Thermal Monitor Enabled
CPU EIST Function Disabled
Bi-Directional Disabled
Virtualization Technology Enabled
UnCore & QPI Features
QPI Clock Ratio x36
QPI Link Speed
Uncore Clock Ratio x17
Uncore Frequency
Isochronous Support Enabled
Advanced Clock Control
Base Clock (BCLK) Control Enabled
BCLK Frequency (MHz) 200
PCI Frequency (MHz) 100
C.I.A.2 Disabled
CPU Clock Drive 700mV
PCI Express Clock Drive 700mV
CPU Clock skew 0ps
IOH Clock skew 0ps
Advanced DRAM Features
Performance Enchance Standard
Extreme Memory Profile (X.M.P) Disabled
System Memory Multiplier (SPD) 8.0
Memory Frequnecy (Mhz)
DRAM Timing Selectable (SPD) Auto
Profile DDR Voltage
Profile QPI Voltage
Channel Interleaving
Rank Interleaving
Channel A, B, C
Timing Setting
Channel A, B, C Standard Timing Control
CAS Latency Time 8
tRCD 8
tRP 8
tRAS 24
Command Rate CMD 1
Advanced Voltage Control
Load-Line Calibration Enabled
CPU Vcore 1.200v
QPI/VTT Voltage 1.355v
CPU PLL 1.880v
PCIE Auto
QPI PLL Auto
IOH Core 1.240v
DRAM Voltage 1.660v
ICH I/O Auto
ICH Core Auto
DRAM Termination Auto
Ch-A Data Ref Auto
Ch-B Data Ref Auto
Ch-C Data Ref Auto
Ch-A Adress Ref Auto
Ch-B Adress Ref Auto
Ch-C Adress Ref Auto
I would be very grateful for any advise given.
Bashy.
Corsair H50
Asus 6870
OCZ Vertex 2E 60GB
Room temp: 22.8C
CPU Ratio 19x
CPU Frequency
QPI Clock Ratio x36
QPI Link Speed
Uncore Frequency
C.I.A.2 Disabled
CPU Clock skew 0ps
IOH Clock skew 0ps
Profile DDR Voltage
Profile QPI Voltage
Rank Interleaving
Channel A, B, C
Timing Setting
CAS Latency Time 8
tRCD 8
tRP 8
tRAS 24
Command Rate CMD 1
CPU Vcore 1.200v
CPU PLL 1.880v
PCIE Auto
QPI PLL Auto
IOH Core 1.240v
DRAM Voltage 1.660v
ICH I/O Auto
ICH Core Auto
Ch-A Data Ref Auto
Ch-B Data Ref Auto
Ch-C Data Ref Auto
Bashy.
