Help!!!! Password forgot with linksys
I dunno, but if it's the default you've forgotten then it's blank for username and "admin" for password. Sorry if this is a little patronising, not intentional.
Check the manual (online if you have lost the hardcopy). There is a small recessed button which needs to be pressed in. Usually you have to do this while turning on the device. Check manual for exact order.
This will then reset everything to factory defaults. So you are going to have to setup your WiFi and ADSL logon again. :)
Hint - when you set the password this time, put it on a sticker and hide this on the base of the router. ;)
