Hey guys,
The other day my Dad's PC died. Like completely died (does not boot at all, fans do not even twitch, no lights at all inside the case nothing.)
I don't have a lot of time so I instantly bought and installed a new PSU as I figured that must be the problem as I'd never seen a PC be a 100% dead(apart from PSU issues.) Turns out this has nothing todo with it, PSU all installed correctly, still same as before, no response at all. I've tried shorting the power-switch on the mobo aswell as the case is pretty old but still nothing. I guess it must be the motherboard?
This was installed from OCUK so it's not even that old(17 Mar 2015):
Pre-Built Upgrade Bundle - Gigabyte Z87-HD3 Intel Core i5 4670K 8GB Kingston HyperX Genesis 1600MHz
Antec TruePower Classic 550w '80 Plus Gold' Power Supply
PSU replaced by: Kolink KL-600 600W '80 Plus Bronze' (pretty sure the Antec is fine after this did not fix it.)
Is there any tests we should do to narrow down the problem, surely if it was the GPU or RAM or even CPU it would boot for a couple of seconds or show some life?
Any help would be great.
Thanks!
Xerco
Thanks!
Xerco
