- 26 Jan 2005
Well I seem to have a puzzle on my hands if some one could please help.
Recently my pc in my spec failed to turn on. Looking at my motherboard I could see the orange power led was on.
Right I thought I have power, so unplugged the motherboard power cable and jump started the psu. Now all the fans (connected via motherboard), and HDD and DVD Roms started up. So I thought the problem was with either the motherboard or the power switch. So I got a jumper and crossed the power on pins on the motherboard and still nothing. Right I though its the motherboard got to be.
So off I went and purchased a new A8N-SLI Deluxe. Removed all the componets from the DFI motherboard and transferred them to the ASUS plugged it all in and again the green power LED is on.
Pressed the power button and nothing. Ok i thought so I started unplugging hardware HDD and DVD Roms, keyboards mice everthing. Tried the power button again and nothing. Then I removed the gpu and tried again and again nothing.
So i thought better check the PSU again, so with the PSU plugged into nothing I jump started it. Now only the rear fan spins up. So i thought lets get the multimeter out. Tested all the rails and they all displayed 0v and this is where it gets weird, after playing around with the psu I discovered that if the psu is plugged into a DVD-ROM and jump started there rails all supply a current. Testing the psu with the multimeter all the rails had voltage, and now both fans were spinning. So I am confused, why would my psu do this?
Oh and my psu is a hiper 580w modular thingy.
Also if its not the psu and not the motherboard and its not a HDD or ROM drive, then it must be the CPU right, but correct me if i am wrong the CPU shouldn't stop the motherboard from booting.
I know this has been a long post and if your still reading thank you and I beg you please help.
