HELP - PC switches on, starts up by itself
28 Sep 2014
ASrock Z97 Extreme4
4790k
SF Leadex Gold 750w
Any idea why my system seems to automatically power on by itself?
Seems if I don't switch it on for a day, it decides to switch on all by itself.
I've checked the settings under power options in Windows and also CPU advanced options in bios where anything to do with "wake" is all switched off by default?
Getting a bit annoying.
What OS? If you are on windows 10 and maybe windows 8, it can turn computers on for updates and automatic maintenance.
Cant remember the exact location as I'm not at my pc but could be worth a look.
I'm on Windows 10.
Checked all power settings in the main power settings menu and also, wake on Land etc in the bios too and everything is turned off.
I'm hoping its something to do with "Hybrid sleep" as just noticed that's the only option that's turned On.
