- 18 Sep 2019
Recently built a pc with the following spec:
Motherboard- MSI B450 TOMAHAWK MAX
Case- Kolink Observatory Case
PSU- Bitfenix Whisper M Series 650W 80 Plus Gold Modular Power Supply
SSD- Samsung 500GB 860 EVO SSD
GPU- Sapphire Radeon RX VEGA 56 Pulse 8GB
HDD- WD 1TB Blue Internal Hard Drive
CPU-AMD Ryzen 5 3600 with the stock cooler
RAM- Corsair Vengeance RGB PRO 16GB
The computer turned off in planet coaster and dirt rally 2.0. It normally shuts down within 5-10 minutes. However, sometimes it may shut down after 20 minutes or so. The pc runs completely fine in CSGO.
Checked the PSU for malfunctioning fan and no sign of a problem.
Also monitored the temps while gaming and they are running at 55-70 degrees for the GPU and 70-80 for the CPU so dont think its temperature related.
GPU driver is updated and the Bios is currently on V30.
Any help would be appreciated, Thanks.
