Help! PC won't post.
18 Jul 2009
UK
My PC has died. :(
Half way through a game of Company of Heroes my PC just shut off, no bsod or anything - it just went off. Then when I tried to put it back on, the fans just spun and it didn't post or anything, they just kept spinning!
So, I turned it off, cleared the CMOS and Windows loaded - eventually. I had to go through startup repair first.
Then, after use, I switched it off and had to go through the same process every day for a few days to get it to boot, it was most annoying.
However, it has now completely stopped working. When I push the power button all that happens is the fans spin for a second or so before switching off.
I initially thought it was a PSU problem, but I reckon it's more likely to be a motherboard or CPU problem.
Both are under warranty, so I can RMA them if necessary.
Oh, my spec:
AMD Phenom X4 955 BE (stock)
Asus Crosshair 2 Formula
4 GB OCZ Platinum 6400
2x WD 500 GB hds
XFX 9600GT
Trust 570W PSU
Thanks in advance!
Then would did it keep going for a week? There's absolutely no burning smell or burn marks on any of the components and when it went off first time it didn't make any strange noises. I've tried the ram trick, pulled my card out etc - all to the same result.
Will try with my brother's components... if he'll let me!
I have a surge protector, a big, hefty Belkin one.
Swapped out all parts and tried a different PSU - same result. My PSU works fine, so it is definitely the mobo.
Will probably get a new PSU soon though. :D I have had an RMA request approved so I will be getting a replacement within a week...
*hopefully*
