- 28 Nov 2009
- Manchester
IF YOU RUN A CROSSHAIR III MOTHERBOARD WITH A QUAD CORE DO NOT UPDATE THE BIOS TO THE LATEST THUBAN SUPPORTING VERSION!
<<I have had a look online and non thuban users (quads for certain, possibly x2/3) who have done will get the following issue- solution is to roll back bios which can be a hassle- looking into a way now.>>
Updated my bios as I have always had issues with C&Q limiting the overclock on my board, can get to 3.7, any further it stops working.
Well got the latest bios, installed it, and tried to boot with 4.0. Started up and it was stuck at 4x multi giving 800 htz.
Disabled C&Q, rebooted, bios post shows the speed I want, once into OS, in everest and cpuz it sticks at 800 still- through stability testing or anything.
Only times it ll come off 800 is when I go back to my 3.7 overclock, or set it all to auto. The 3.7 overclock seems to take a few minutes to recognise what is happening, then works fine.
Set it to 3.8 and boot and it starts doing all kinds of bizarre stuff. C&Q enabled the voltage is at 1.45 when its set to 1.41, cool and quiet sits at 800, flicking about randomly, went up to 1.6 once, and 0.136 a few times. Same with any other multi...I can't actually select a 4x multi in my bios so what the heck is happening?
I also cannot flash the bios back- when I go into the ez flash utility, it tells me any other bios made before the one I just installed is older then the board, or does not have a valid boot sector.
Tried uninstalling the asus C&Q driver, no change.
Any help is appreciated, I am pretty lost here. Spec as below.
