Help (PHP)
3 Oct 2003
Northampton,UK
Hi guys,
Iv'e started to learn php today and i have run into a few problems.
Im following a php book and have tryed an simple php html form example.
I have made 2 pages one html page with input forms and a php page which outputs the variables that the user entered. The code for both is:
<HTML>
<HEAD>
<TITLE> HTML TEST FORM </TITLE>
</HEAD>
<BODY>
<FORM ACTION="HandleForm.php" METHOD="POST">
FIRST NAME <INPUT TYPE=TEXT
NAME="FirstName" SIZE=20><br>
Last Name <INPUT TYPE=TEXT
NAME="LastName" Size=40><br>
E-mail Address <INPUT TYPE=TEXT
NAME="Email" SIZE=60><br>
Comments <TEXTAREA NAME="Comments" ROWS=5 COLS=40></TEXTAREA><br>
<br>
<INPUT TYPE=SUBMIT NAME="SUBMIT" VALUE="Submit!"
</FORM>
</BODY>
</HTML>
And the php page that handles the information is suppost to just echo the data back to the user:
<html>
<title> Results </title>
<?php echo $FirstName; ?>
<?php echo $LastName; ?>
<?php echo $Email; ?>
<?php echo $Comments; ?>
</html>
However when running these and clicking submit no data is displayed on the screen as if the variables are empty!
What have i done wrong!
Cheers,
Eddie
Firstly, please use code tags when posting code :)
The problem you are experiencing is related to the register_globals directive.
Namely, the book assumes your PHP installation will have this enabled, which in many peoples opinions is a no no, and register_globals is actually disabled by default.
A better way to access any POST variables (your form is using POST as the method of transferring request data), you can access them in the $_POST superglobal array, like so:
Code:
<?php
  echo $_POST['FirstName'];
  echo $_POST['LastName'];
  echo $_POST['Email'];
  echo $_POST['Comments'];
There is more to it, including security, but that should get you started :)
Add <br />\n to the end of the echo to seperate each variable onto a new line if needed :)
Code:
<?php
  echo $_POST['FirstName'] . "<br />\n";
