I do a nice little deal actually
OcUK Symphonia Headphone Amp and Soundcard Bundle @ £99.90 inc VAT
Winner of Best Headphone Amplifier of the Year 2012 – Hi-Fi World Magazine
The Epiphany Acoustics EHP-O2 is a battery powered portable headphone amplifier which has been designed from the ground up by electronic engineer 'NwAvGuy' to offer some of the best, if not the best, specifications and hi-fi functionality on the market today. This has been accomplished by months of development using top of the range audio testing equipment to fine tune and carefully select the most optimum design, layout and components. The specifications achieved speak for themselves.
- High power output
- 2 x high capacity rechargeable batteries
- Highly optimised component selection and circuit design
- Ultra low output impedance
- In built power management circuity
- 1 x 3.5mm analogue input
- 1 x 3.5mm headphone output
- 1x and 5x gain settings
Technical Specifications:
- THD @ 1kHz: 0.0017%
- Noise level (ref 400mV): -105dB
- Power output @ 33O : 641mW
- Crosstalk: 65dB
- Channel balance: 0.6dB
- Output impedance: 0.5 Ohms
- Battery life: up to 11 hours
- Dimensions (W x H x L): 108.5mm x 30mm x 82mm
Included Accessories
- AC adapter
- 1.2m mini jack interconnect
- 4 x self adhesive rubber feet
Soundcard
The Xonar DGX sound card combines Dolby Headphone 5.1 high definition surround with Asus’ own GX 2.5 gaming audio engine and an on-board headset amplifier. These result in accurate and deep audio that brings every nuance and sound across fully, making the new Xonar DGX an ideal sound card for gamers who want to remain totally aware of their play environments.
- Built-in Headphone AMP
- Powers up every sound detail in gaming
- 3 gain modes for different usage scenarios
- Dolby Headphone for an immersive 5.1 surround imaging
- GX2.5 for realistic 3D audio effects
- PCI-E
Only £99.90 inc VAT.
ORDER NOW
