- 23 Sep 2009
- London
So I've been out of the game for a good few years and due to lack of time, I've had the following just sitting around at home for 3 years gathering dust!
*Corsair 1000D case
*Asus Rampage VI Extreme motherboard
*Overclockers binned Core I9 7900x rated to hit 4.6 - 4.8 (need to check), with the EK full cover plexi RGB waterblock
*4x16GB G.Skill 3600mhz RGB Ram
*1tb Samsung 960 Pro m.2 NVMe SSD
*2x Asus Strix GTX 1080ti with Phanteks waterblocks (barely used!)
*12x White Monsoon EV2 Hardline compression fittings
* 8x 90 Degree White Monsoon EV2 hardline Fittings
* 16 tubes of Monsoon PETG 3/8" x 1/2"
*2x Alphacool NexXxos XT45 480 radiadtors
*1x Alphacool NexXxos XT45 420 radiadtors
* a ton of Corsair LL120 and LL140 RGB fans with led and fan controllers
* 2x Corsair commander pro's
Main reason they've been sitting wasting money is giving up after trying to plan the tube runs.
Here's a pic of how it looks at the moment:
(Needs a lot of dusting and cable management)
The 2x 480's will be mounted with the G1/4" threads at the bottom with 90 degree fittings and extenders but I've removed them on the tray that comes with the 1000d for the time being. The top 420 has the G1/4" threads facing the rear as otherwise they get in the way of the front 480's. Most builds I've see have a 360mm rad up front and combined with the front 480's instead as having a 420mm up top like mine causes issues.
Any advice and ideas on how I can plan the loop, I've considered running a couple to the rear section behind the motherboard tray using soft tubing but I gave up with that idea.
Appreciate any help or advice.
*Corsair 1000D case
