Help Please!! 22" - £150
5 Dec 2010
OK guys I need help!
I have looked at soooo many monitors and I'm hopelessly confused :)
What I need is a screen suitable for work, gaming and movies
I have been looking at the 22" mark, as I think that 24" is just too big (what do I need with that space???). also helps to keep cost down :)
My budget is around £150 so I have found various things:
LG Flatron W2261V-PF (£145)
BenQ G2220HD (£100)
Samsung Lavendar P2250 (£150)
Dell ST2220 (£130)
Samsung 2333T (£130)
I'm a bit confused as to why the benq is much cheaper than the others???.... I was thinking about getting a samsung as that I what I have at the moment and has been very good... Again why is the 23" one cheaper than the 22"??
I have been unable to find any screen with a height adjustable stand + tilt + rotate, which is ideally what I want.... Do these exist for my price range?? Or can I use the stand I have at the moment and screw the new monitor on??
Please give me some advice!!!
Thanks very much!!!!!!!!!
