Need some help to figure out what is going on, I have just gone from 3.760GHz(188 base clock, 1.265v core) to 4.00GHz 200 base clock and 1.375v core, but I have a problem where my ram usable has gone down to 1.99GB (out of 4GB)usable in windows 7 64 bit, this problem was not here at the lower clock settings.
Any advice on how to overcome this issue?
Have you had this issue before?
Anything I can try, memory is running at 1600MHz at 1.65v in the bios
, I'm guessing this is too much, what should it be and I will set it manually and try.
, so it's better to run at 4GHz then and sacrifice memory speed, will do some more digging with voltages when brave enough to see if I can sort this out, shame I only have 3 memory options
