Here you go. I really would'nt have thought you needed one for a 1650Pro. I have a 1600XT in my second pc running with the stock cooler and it does'nt get very warm and is pretty quiet too.
Thanks pastym. I have a weird version of the 1650 - is cheap and noisy. And the Accelero doesn't fit! The screw holes in the card don't line up. New card time.
As its an older and cheap card, i'd personally rip off the fan, whilst leaving on the heatsink and stick on a low rpm 80mm or 120 mm one and cable tie it on.
I'll probably cool just as well.
I've got a 3870 xt powercolour OC'd one and i removed the cheap and noisey fan and cable tied on a 120mm sharkoon.
I can now only hear my HDs and CD drive spinning,
Cheapo mods all the way, also that cooler is probably worth as much as your graphics card !
