I'm a bit of a novice when it comes to networks, routers etc, but I've been asked to assist my in-laws with an issue.
They've recently upgraded from an old (non-wifi) ADSL modem to a Thompson TG585v8, supplied by Pipex. Their desktop is an ancient AMD XP1900 running XP SP3. It connected perfectly well to the net using their old modem, but doesn't want to play ball with the new one.
I've tested the Thompson with my laptop, and it connects without any issue at all - so the issue with with the desktop setup.
I've clicked on the network symbol in the tray(?) (bottom right corner of the screen) and it brings up the Local Area Connection Status. In the General tab the Status stays on "Aquiring network address". Activity states 5 packets sent and 7 received. It just hangs there.
On the support tab the Address Type is "Invalid IP Address". The IP Address is 0.0.0.0, as is the Subnet Mask.
So, the question is, should the IP address be changed to solve the problem, and if so, how?
Thanks!
Thanks!
