I've been trying to get the following rig up and running for a few months now:
Gigbyte GA N680SLi-DQ6 Rev.2
E6600
OCZ 2GB (2 x 1GB) PC2-8500 1066MHz Reaper HPC Edition Dual Channel DDR2
Western Digital Raptor 150GB WD1500ADFD 10,000RPM SATA 16MB Cache
320MB BFG Technology 8800GTS Overclocked, PCI-E, Mem 1600MHz, GPU 550MHz
750W Xclio PSU
Samsung SH-183LBEBN 18x18 DVD±RW Dual Layer Serial ATA Lightscribe ReWriter (Black)
Now I can't for the life of me work out whats wrong.
I've RMA'd the motherboard and the memory.
I've tested with another 750 Xclio PSU which runs my media centre 24/7
I've put the CPU into another machine and it was 100% stable.
I've tried another hard disk (though I am going to try one other as I'm not 100% sure the one I tried was healthy)
All the BIOS settings are default except the memory which I had to add 0.5v and set it to Max OC to get it to read the SPP EPP and now the memory is running at 1066MHz and the correct timings and the CPU is at 2.4GHz I've checked this with CPU-Z too and everything is set correctly.
Originally the computer would keep saying ntoskrnl.exe was corrupt just as it got to the bit where it loaded XP.
Now I have Vista x64 on it.
When I turn it on it gets to the bit where it's just about to start loading Vista and restarts, however on the second time round it loads Vista no problem at all and appears to be stable I've stressed it for about 9 hours with Orthos.
What on earth can cause this kind of behaviour?
Any help would be greatly appreciated.
Cheers,
Jack
E6600
750W Xclio PSU
Cheers,
Jack
