I have a zoom x3 BB modem plugged into an RV082 Linksys router.
Now when the my pc is plugged directly into the Zoom unit, my connections and speeds are fine.
When I plug the modem into the RV and then my pc into one of the switch ports I get a very slow connection / or no connection at all.
I can't work out why, I've done a factory reset on both units (seperately) and reset all details as they were before, but I just can't see a reason for it.
Both units say they are working fine together.
Any ideas?
Thanks
Any ideas?
Thanks
