Help please: CPU fan refusing to spin.
24 May 2004
Manchester
Hi there
Done a new build today, first in a long time and was hoping for no problems. I am getting to a Asus boot screen but the CPU heatsink fan powers up for about 2 seconds and then stops. Bit worrying as I don't want the cpu frying.
Anyone any ideas? as I don't dare go any further!
Also from my corsair PSU do I plug both the 12V+ in at the top of the motherboard. The Asus manual says I should plug the 8 pin but there was a bung in one of the 4 pin parts. Totally confused by this.
/Edit Sorry in advance if I am being stupid, been using a mac for 5 years!
Thanks in advance.
Total specs.
Intel Core i5 750 2.66Ghz
Asus P7P55D Intel P55 (Socket 1156) DDR3 Motherboard
Corsair TX 650W ATX SLi Compliant Power Supply
Arctic Cooler Freezer 7 Pro Rev 2 CPU Cooler
Sony Optiarc AD-7241S 24x DVD±RW SATA Lightscribe Optical
Edimax EW-7128G 54Mbps Wireless PCI Adapter
G.Skill Ripjaw 4GB (2x2GB) DDR3 PC3-12800C7 1600MHz Dual Channel Kit (F3-12800CL7D-4GBRH)
Remove the bung and connect the 8-pin connector or the 2 4-pin connectors.
Mine does that too but when it stops spinning after 2 secs, it comes on again like 3 secs later. Have you waited to see if it starts spinning again?
Hmm bit more googling and I have read (from what I understand) that the fan will only kick in if it needs to?
Anyone had experience with this before, last time I built a system a CPU fan would be running constantly?
I tried waiting about 10 seconds but its not booting into anything as I have nothing installed. Its just sat on the asus screen asking if I want to head to bios.
The boot screen actually says CPU fan error but it does initially spin up. I can enter the bios fine and the CPU temp is at 32-34c.
The processor turns off if it gets too hot, so no worries there. I think its the board refusing to post, perhaps it's shorting on something or you've missed a cable.
The fan itself can be tested by connecting it to the psu, with appropriate cable, and wiring the green to a black on the 24 pin plug. I'm sure the fan is fine though.
^this would have course lead to the fan spinning flat out for a few minutes then the computer turning off. Remounting the cooler isn't the answer here.
No worries peeps, I stopped being a wuss and booted to the Vista disk and the fans spun up. It appears the cooler only kicks in when it needs to?
Fingers crossed I can get through this smoothly, hate this feeling.
/edit thanks by the way.
