Hi Guys,
Wonder if you can help with this one. I have a good search around but with no luck.
First of all,
System:
AMD64 – 3200 1meg cache, 1024 OCZ Ram //ATI X800 pro 16 pipe // windows XP SP2 // 2X SATA Drive with all programs installed on the 2nd drive to keep it in shape. I’m very careful of what goes on there and run disk keeper10 & plenty of spy ware software…
Problem:
Everything is running great with no problems at all apart from this
I am getting an odd slow down problem when I put a window over an icon on my desktop. I use Avedesk or Object dock.
These are PNG’s not sure if .Ico format would improve.
So basically I can grab a windows move around my desktop any speed I want but as soon as it goes over the icons from one of these programs it goes very slow indeed.
I wouldn’t normally be too fussed about this but every time I load Windows blinds and have anything over the icons it really grinds to a halt.
I have a system at work with a setup close to this expect it has a nvidia 6200 the problem does not happen at all there.
Thanks for any information or help you can give on this one.
Thomas
[img=http://img222.imageshack.us/img222/5766/slowdown8**.th.jpg]
http://img222.imageshack.us/my.php?image=slowdown8**.jpg
First of all,
System:
Problem:
Thomas
