- 19 Oct 2002
- Glasgow
My friend got her teenage son a gaming Pc for Christmas, pre built but without an OS. She got Windows 8.1 & installed it (well I did) Mobo Drivers, Windows updates etc. Everything goes smooth, no problems. Restart after the graphics drivers and it starts up then says graphics drivers require a re-start to complete the installation which just does the same when re started.
On checking in device manager its giving an exclamation mark at the card.
I've tried uninstalling the drivers and re doing them from here, tried various drivers including the newest non beta and they all install fine then once you re-start same old problem.
The resolution also jumps down to well below the monitor spec and gameplay is laggy. If we uninstall the drivers and re start the card is able to do full monitor resolution using the windows drivers and without asking us to restart to complete the installation? I'm at a loss as to what's going on, have even done clean installs 3 times still no joy. She has contacted the company she bought it from for advice but they have not been very helpful. So now she has a 13yr old son with an unusable gaming PC for his Christmas.
I can't help think it's a simple fix but can't think of what it could be?
The Pc Spec is as Follows:
Case: Zalman Z11 Plus
OS: Windows 8.1
Power Supply: XFX 550W
Mobo: Gygabyte 970-DS3P
CPU: AMD PileDriver FX-8350 (Corsair H55 Water Cooling)
Graphics: Palet GTX 970 4gig
Ram: 8GB DDR3 1600MHz Dual Channel Kit
Hard Drive: Seagate 1tb ST1000D M003
Sound: Realtek ALC887 - 2/4/5.1/7.1-channel
Optical Drive: 24x DVD+/-RW SATA Drive
OS: Windows 8.1
