Ok here's the situation. I use a BT HH5. I run my main PC via wireless using a Archer AC1200 usb adapter. About 8 ish meters away from the router with 2 thin walls between. Connects at 520 - 585MBps. Great.
However, my son is doing a lot of video and photo stuff on his pc. He is connected via wireless too on a 300mbps adapter. He is in the opposite corner of the house from the router, connects at 48 - 72mbps. Usually 72mbps all the time. So I would like to purchase an extender, either the tp-link re200 AC750 or the tp-link TL-WA850RE 300N.
My pc will be closer to the extender than the router. Will getting the RE200 extender limit my wifi speed to 433mbps? (Max speed on that AC Adapter) Or worse yet if i get the WA850RE will that limit me to 300Mbps?
Power line is not an option. No spare sockets. Extender will work fine. But I don't want to lose 150 - 300mbps off my link.
So question really is, if I use an extender will my machine connect to that at the 433mbps max vs connecting directly to the router at higher speed?
