Hi all,
Been trying to work out what is wrong with one of my family's pcs that I built and need your expertise!
For the last couple of months the machine has been experiencing vertical lines accross the screen and coloured dots (artifacts). But it only happens randomly. Sometimes it can go for a week without doing it and then it will happen and you can not get rid of them by restarting, shutting down, psu off etc. Quite often the machine will hang shortly after the lines appear but sometimes you can continue to use machine.
I have tried swapping the graphics card over, did not fix it, and I have just swapped the ram. When I did swap the ram it was still showing the exact same lines, I went into safe mode, was still showing them, did a restart and then they dissapeared and I am now here on the machine typing this.....
Its not driver related as it does it when it first turns on with bios info etc.
Could it be a faulty motherboard? The cpu does not seem to be overheating, all cores sit at about 40-42C idle. And I have changed the graphics card over in the past so im sure its not that...
Or can the processor just go dodgy?
The machine has been running fine for a year or so previously to this problem.
The machine specs are:
Intel i7 920 (Bloomfield)
Gigabyte EX58-UD3R
6GB OCZ PC3 12800 (Now has 4GB of my much higher spec ram in)
ATI Radeon 4870 X2 (Have tried my old 4850 and still had prob)
Here are two images:
Thanks in advance guys!
Gigabyte EX58-UD3R
