HELP please, Motherboard and ram settings, crashing problems
17 Feb 2006
I am experiencing games crashing all the time. I have recently upgraded to a new Lian Li V1000+ case which I thought had fixed the problem with better cooling, but it started again today.
A while back my motherboard lost all its settings and I have chosen AUTO for most of the setup but would like someone to confirm the setup is correct and not causing any problems.
I am currently running:
DFI Lanparty Ultra B
Barton XP 3200 512L2 Cache
OCZ 2x512MB 3200 Platinum
ATI AGP 800XT PE
Raptor HDD
My Gcard temp in games is around 50-52.5
My memory in games is 40-44
Everything else is pretty cool.
Here are my motherboard settings:
Advanced Chipset
System performance: Optimal
greyed out
CPU interface: Optimal
Memory timings: Optimal
T(RAS): 6
T(RCD-Read): 3
t(RCD-Write): 3
T(RP): 3
CAS Latency: 2.0
T(RC): 13
T(RFC): 15
Genie BIOS Settings
Current CPU frequency is: 2200Mhz
CPU Clock Spread Spectrum: Disabled.
CPU Clock Settings: 200Mhz
AGP Clock Setting: Auto
CPU Ratio: X 11
DDR DRAM Clock: By SPD
Current DDR Frequency is: 200Mhz
Current CPU Voltage is 1.63 V
Current DIMM Voltage is: 2.59 V
If anyone can help I really would appreciate it. Should I manually set the DIMM timings and should I change the voltage?
Have you tried one stick of ram at a time? Try each stick individually. Sometimes you may find that they don't work together or one may be iffy.
You can still run with just one in though, will just mean that you have half the RAM. Have you tried running Memtest on the sticks?
