Hi again,
I would like some more advice please.
So I ordered this system and the parts arrived today and I assembled everything by following this guide while reading my specific motherboard and hardware manuals for installation instructions. (It’s my second build – I’m fairly competent.)
Important Note: I’m trying to use an existing CRT monitor driven by a DVI-D cable with a DVI-VGA adapter.
Everything went OK until I tried to boot the system. No beeps at the start at all which is quite worrying because the P8Z77-V manual says “One short beep: VGA detected, quick boot set to disabled, no keyboard detected.” So possibly it’s not detecting the graphics card. The fans on the card both spin so it is powered up.
However, the monitor output remains white which is what it does when there is no signal to it. I thought the PC continues to boot, however, and the keyboard lights flash and no warning lights on the motherboard are on. However, nothing displays on the screen. Eventually the boot LED remains on because it cannot boot an OS.
Plugging the DVI connector into another port on graphics card does not change things. Plugging the DVI into the motherboard video out also doesn’t work. Plugging the VGA cable from CRT into the motherboard VGA port also doesn’t work.
However, removing the GTX 570 and using only the integrated graphics with the VGA results in video output and allows me to boot bios and start installing windows 7. CPU temperature is ~27C. Removing the GTX and using the DVI output on the motherboard also does not work. It seems the only solution is to use the VGA on the motherboard.
However, in the graphical BIOS on VGA I cannot see the whole menu screen and it appears to be cropped when I do load it to only the top left of the screen. I also don’t see any white text of any description describing the hardware prior to loading graphical bios by pressing delete.
Is the graphics card dead?
Is the DVI adapter/cabling broken or faulty?
If the graphics card is broken, I presume there’s nothing I can do to it apart from RMA’ing it?
If I do have to RMA it, can I continue to install Windows 7 on integrated graphics and run for a while until the part comes back?
Or is it the fact that it’s not possible to run a CRT from the 570 with a DVI to VGA adapter? In this case I would need a new monitor. However, I don’t really want to have to buy one just yet.
What is likely wrong with it and what’s the cheapest and easiest way to find out what it is?
