Help Please:- pc clock is running 20 minutes fast per hour
21 Feb 2004
Canterbury
As the thread title,
my pc clock has started (in the last 3 days) running 20 minutes fast per hour.
I've run an up to date virus check, rebooted numerous times, time sync'd with a server etc and nothing helps.
does anyone have a clue what could cause this?
It doesn't coincide with new software installations, my system isn't overclocked or anything and it has run fine for nearly 3 years with nothing like this. Even the IT guys at work are stumped.
You say 3-years? Might be CMOS battery, though that would cause it to loose time not gain. Maybe synchronisation issues with Internet Time servers :confused: Try disabling Windows Time Service :D
Do you mean it will be the correct time but then go faster by 20 mins every hour?
Try just putting the time in yourself.
MC_Bob
I can only suggest replacing your battery.
If that doesn't work, new motherboard time. :(
All is not lost!
Assuming you either can't be bothered to replace the battery or that doesn't solve your problem, use Tardis 2000.
I used it on my old Nforce2 system which ran similarly fast and it simply updates the time from a choice of hundreds of servers at whatever interval you choose (I had it set to 30 minutes which was fine for mine).
You'll need to download it from http://www.kaska.demon.co.uk/ (it's shareware but doesn't have any features removed for freeware users).
Install it and have it run every time you start Windows - it uses virtually no resources and sits in your system tray.
You should also stop the 'Windows Time' Service using the services control panel in administrative tools.
