Help please (Urgent!!)
1 Dec 2004
S.Wales
Iv just setup a new HTPC build, its using the new Gigabyte GA-MA78GM-S2H mobo was just about to ghost the hard drive, before i did on bootup there was a message kept popping up about the SATA HDD installation, press Y to continue, so i pressed yes as it didnt say "im going to wipe your drive" or anything that could have looked dodgy. and it went into something called Hyperdrive utility , now everytime i try and boot the PC up, it asks you if you want to enter this utility, if i leave it, it the windows splash screen will load for a second then it will blue screen....
I get the stop code:
Stop 0x0000007B
Has all my hard work gone to waste or is there anyway of recovering this?? iv looked in the bios but cant see anything in there really that would help?
