[HELP PLEASE] "Windows System Notification Service" could not connect.
8 Jul 2010
Staffordshire
Today I've been getting a message pop up as I log in on my laptop that says "Windows could not connect to the Windows System Notification Service service". A confirmation box appears above it (similar to what you get when you mistype a password while logging in). I clicked ok to load the desktop and the screen went black as usual just before the desktop is loaded. I can still see and use the mouse pointer but the screen stays black.
After twenty minutes the screen is still black so I reset the laptop and start in safe mode. I can log into the admin account on the laptop and the desktop loads but a system tray notification comes up saying the same thing as the previous notification only with an extra bit about how I can check the event logs to diagnose the problem as I'm an admin. The other thing about the admin account worth noting is that aero is disabled (it's usually enabled). In the meantime, I use my PC to search for resolutions.
I do the following (in no particular order)-
1. Scan for viruses using MSE with an up to date definitions database.
2. Scan with MalwareBytes, also up to date.
3. I install two windows updates (I always keep the system up to date).
4. I try the "NETSH WINSOCK RESET CATALOG" command which, apparently, fixes the problem I have described.
5. I use the "sfc /scannow" command and it doesn't find any faults.
6. I try restoring the laptop using a restore point from a couple of days agao when the laptop was working absolutely fine.
7. I check to see if the "System Event Notification Service" service is enabled on startup which it is but I can only check it's status on my non admin account when it is in safe mode. Again, even though it isn't loaded in start mode, it says that it starts automatically on startup.
So far, nothing has worked. Is there anything else I can do that might fix this issue?
I've just tried logging in again having read that if I leave the laptop for a while after booting, I will be able to log in. I left the laptop for ten minutes or so and then logged in. Again, I had the message pop up, I clicked ok and the screen went black but this time I left the laptop until it did something. After about ten or fifteen minutes I saw a flash of what I thin was the user selection screen before the screen went black again. Another minute or two of black screen an then the user account selection screen appeared... no notifications or messages about a failed log in though. I've just tried logging in and I was able to do so on the limited account. First thing I did was check see if " Windows System Notification Service" was running and it is.
I'm just running another sfc /scannow thingymabob before I reboot (as I'm not sure what else I can do).
Just rebooted, same thing happened. Ten minutes of black screen before the account selection reappears and then I can reselect the account, input my password and log in as normal.
