Help Please with case/fans
17 Nov 2010
Hello All,
need some help i have a full tower NZXT Phantom 820 i case
i have several fans put want to the know the best fans to use and placements ( push pull etc)
i have a H100 with 4 Corsair SPfans on push pull at the top and ( 120mm)
1 fan SP corsair on the back as exhaust(120 mm)
1 Fan SP corsair in the middle the case pushing towards my SLI 980ti's (120 mm)
2 AFCorsair on the bottom the case pulling air up from the floor 140 mm i think
NZXT case fan on the side pulling air in also
and the 2 fans on the front the case
could anyone help me maybe with better fan choice? or fan palcement etc
was thinking to get 2 nocturna 3k rpm for cpu on push and then 2 good 200mm fans for pull on top the case would this be better?
just need some help dont think my set up is ideal
and i think on my h100 i haven't got 1 corner pinned down so may need get some replacement and get this reseat on the cpu ( i know dont laugh)
temps in game about 30-50( 50 is only if its a hot day tbh
CPU is a i7 4790k at 4.5 GHZ ( no voltage change from stock ) so think i have a good chip tbh did have on 4.8 went initially had it but didnt see much difference so leeft at 4.5
Rampage maximus 7 formula is my motherboard
Hello All,
AF 140 on the rear should exhaust air better than SP 120. SP's shouldn't really be used as case fans unless there is a lot of obstruction. They tend to have less CFM.
I tested the 200m side fan on intake/exhaust/off. Off was a degree cooler. But it depends on the video card, and how many, and where it/they let off hot air.
Default front fan is a 200mm. Which are those two?
For CPU or GPU? Which GPU is it and what temps? Either way that sounds absolutely fine.
