Hi folks,
Never really overclocked a GPU much before, but my reference (OEM so not even a sticker on it) 5850 seems willing so I'd like to set it up properly and would appreciate some advice. Currently has stock bios.
I started out playing around with ATI GPU clock tool and found I could furmark at 875/1200. AMD GPU clock tool appears to automatically raise the voltage to 1.088 when doing this from a default of 1.0. Though it could run furmark in a window, Crysis crashed with these settings and there's no option for higher volts.
I then installed MSI afterburner to have a play with that. I found the graphs in afterburner tally with what I set in GPU clock tool. The frequency sliders in afterburner are limited to 775/1125 which is no good but I found I could override them with GPU clock tool. Afterburner gives higher voltage adjustment so I put 1.2V on then went back to afterburner and set 900/1200. Then back again to afterburner to take back control of fanspeed because changing clocks in GPU clock tool sets fans back to default. So afterburner now reads 900/1200 @1.2V (including on the clock sliders even though if I actually try to use them they dont go up that high!). I can then furmark or play Crysis fine at those settings and good temps - high 60s with 50% fan if I recall.
I'm sure she can give even more, but the current faffing about with two programs every time I want to OC the card is a little annoying.
I'm aware the thing to do is bios mod my card, right? In fact I thought I would have to bios mod it to get voltage adjustment working, but I seem to be able to do that already?? Is that not right?
If I flash it with an msi bios will I just be able to do everything in afterburner - i.e. the clock sliders will go up high enough, instead of having to use GPU clock tool to set the clocks? That would basically be awesome. If so what bios would I use?
Any advice appreciated. Cheers,
Liam
Liam
