- 9 Dec 2024
- uk
If you've just bought the pc, see about returning it immediately and get your money back. You're basically looking at replacing everything if you really want a gaming machine. Sorry to say, no way to be gentle about this. When did you buy it?I’ve just bought the
Pc-Intel i5 2400, GT 710 2GB, 8GB Ram,120GB SSD&1TB HHD Windows 10
I’ve downloaded black ops 6 and it’s just constant laggy, I’ve made the graphics low and it still jumps about! What do I need to upgrade!! When I go on task manager disk is at 100 percent Thankyou x
Daylight robbery if that's the price paidLooks like it may have cost £240 if bought from the Google result I found. OP you should really try and get a refund if you can - it might be marketed as a gaming PC, but it's really bottom of the barrel I'm afraid.
For a calculatorDaylight robbery if that's the price paid
