- 25 Aug 2005
- Derbyshire
Since installing my AMD X2 3800 I keep getting a random problem. The monitor seems to loose signal from the computer when I am playing films etc.
I have tried running memtest, no problems there, and I have run 3dmark06 a couple of times and it has run fine. I am thinking my graphics card is on the way out. The temps on it are fine as it is watercooled (about 38-40degrees load). When playing films, I can still hear the sound from the speakers, but the monitor goes into standby.
If is it the graphics card, what can you recommend for about £250?
Thanks
Thanks
