- 3 Oct 2006
ok, short story, went to change the icon for hard drives in windows to an icon, which is part of an icon 'pack' i found on the net, however, while the rest of the icons seem to have affected nothing (other than a different icon
) the hard drive one seems to have done somthing, which while annoying it can be worked around, but i just want to change it back, ok so basically:
changed icon for hard drives
and now, if i click on a hard drive it opens straight into the search function
now i want it back to the way it was, click hard drive icon, icon opens hard drive, not does the search option.
any help appreciated
edit: looks like this:
want it to open like this (normally ):
edit2: just found out its doing it for all folders within the hard drives, so if i click my my computer its fine, to get to c drive i have to right click and open, or it opens to the search, and then to go to my documents (for example) i will have to right click, open again
) the hard drive one seems to have done somthing, which while annoying it can be worked around, but i just want to change it back, ok so basically:changed icon for hard drives
