help please
27 Jan 2005
Letchworth Herts uk
Hi there can anyone help please ,i am unsure about getting a widescreen tft Monitor ,as i,m not really a gamer ,but i do like to watch DVD films ,is it worth getting one for this ? i,m looking at this model ..any views ..
Viewsonic VX1935WM 19" Widescreen LCD (1440x900) 5ms DVI Monitor
i'd agree with that. If you can stretch to the 20" version, the 2025WM then you get a bigger screen and resolution. More importantly though, you'd move away from the limited TN Film technology, to the more superior P-MVA panel of the 20" model. For movies this would be really good since it offers a much better black depth, smoother, less noisy movie playback, and most notably much wider viewing angles. :)
thxs
Thxs i,m looking into this ,i came up with this model too ,its the same res as the viewsonic 2025 20inch is it any good ? its slightly cheaper.
LG Electronics L204WT 20" Widescreen LCD Silver
The LG has a TN panel (hence the price) so you don't get the better viewing angles of the MVA panel in the VX2025wm.
thxs
Thxs for this info ,and i can see what you mean from reviews ,i,m now looking at this model ,as its got good rreviews ,but i,m now puzzled about the DVI-D cable ,which one would i buy if i got this monitor ,as it mentioned they don,t supply one ? :confused:
Belinea 102035W 20.1" Widescreen LCD Monitor - Black/Silver
thxs
Baddass said:
just a standard DVI-D > DVI-D cable would do the job, only about £10 really
So is this what i want ?
DVI-D Plug 24+1 to DVI-D Plug 24+1 (Dual Link)
-- HIGH QUALITY --
Length: 9.8ft / 3m
*DVI-D Connection Cable
